ni xilinx compile tools 14.4 Error
Hi all,
I tried to compile my LabVIEW FPGA VI with the last version of xilinx compile tools 14.4
I got the following error
I re-installed the ni xilinx compile tools 14.4 TWICEn and the the result is the same.
Help.... please.
(2,745 Views)
As a precision, I have a NI cRIO 9074, freshly unpacked.
(2,744 Views)
I would bet that this is an issue with a botched UNINSTALL of Xilinx 11.5. To fix:
  1. Go to 'C:\NIFPGA\programs'
  2. Do you have a 'Xilinx11_5' folder? If so, I bet it's empty/corrupt. Move it to another directory for this test.
  3. If you don't have one... well then I'm wrong and the issue is elsewhere 🙂
Do you expect to have/need Xilinx 11.5 on the system (for compiling with LabVIEW 2010)?
Cheers!
TJ G
(2,726 Views)
