niScope Configuration Clock.vi Error 1074118538
The attached vi runs without error with the PXI-5102 Digitizer.  When run with the PXI-5114, I get niScope Configuration Clock.vi Error 1074118538.  The error description is "Specified source or destination is invalid".  I am using LabVIEW 8.0 and niScope 3.0.  Any ideas?
Thanks in advance.
(2,517 Views)
Hi VI Joe,
Some of the VIs you have in there are 5102, specific. Best way to do synchronization with the 5114 is through TClk. A good example can be found in the LabVIEW Example Finder under Hardware Input and Output->Modular Instruments->Digitizers->Synchronization.
Rohan B
(2,502 Views)
