nidaq32k.sys BLUE SCREEN Driver_Left_Locked_Pages_In_Process
Driver NIDAQ32K.sys causing blue screen of Windows XP machine. With error message Driver_Left_Locked_Pages_In_Process
I assume the appropriate action to take would be to update this driver?
Would you agree with this?
Driver version is 7.512.3.1 NI-DAQ Windows NT Kernel Driver @2004 National Instruments Corporation
Regards
(3,817 Views)
Hi Ben,
Updating the driver is certainly worth a shot, this does however have an underlying problem with XP itself (and I'm sure it's something the states are looking at) so a few of our customers have found the only fix at the end of the day has been to do a reinstall of XP itself. I realize this isn't a perfect solution but the XP reinstall does solve the underlying problem to do with the memory error and BSOD that you are seeing.
(3,799 Views)
OK, thanks for your response. I will rebuild the machine, and let you know the results.
Regards
Ben
(3,797 Views)
No problems,
Apologies again for the issue, let me know how it all works out.
(3,795 Views)
