"Unexpected licensing error"
Trying to install LabVIEW v8.2 on my laptop using a disc provided by the IT shop under my university's license.
LabVIEW will not initialise with pop-up message:
"An unexpected licensing error has occured. Please contact National Instruments Technical Support at ni.com/support to resolve this issue.".
License manager does not exist after install. Help files work, as does the Measurement & Automation Explorer.
Only things to appear in the start menu under National Instruments:
Data Socket >
LabVIEW 8.2 >
Variable Manager >
NI Registration Wizard
Any ideas?
(3,273 Views)
Hi there
This kind of licensing error it is probably due to a limit of some kind on your universtitys licence having expired or been reached.
My best recomendation to you you would be to phone 01635 523545 and explain that you have a licence issue.
this is the best way as to confirm your details I would need your serial number it is not best to post this online.
Graham
Graham Green
Software Product Marketing
NI | Emerson
(3,249 Views)
