03-05-2007 04:48 PM
03-07-2007 10:25 AM
03-08-2007 06:56 PM
03-09-2007 02:56 PM
03-10-2007 06:56 PM
03-12-2007 11:56 AM
03-12-2007 04:38 PM
10-05-2007 01:03 PM
10-05-2007 04:30 PM
10-08-2007 09:03 PM
Hi Rogerio,
Was this setup working before and this is the first time you’ve seen this behavior? Does this happen on another computer? This may not be a faulty card, given your setup is completely different.
To know what hardware is supported with what version of the driver and what operating system, see the Data Acquisition (DAQ) Installation/Configuration Troubleshooter
It appears that DAQmx 8.0 is the last version to support
Linux systems. Its readme can be found by visiting www.ni.com/support, clicking on “Drivers
and Updates” and searching for DAQmx. It contains compatibility information as well as Frequently Asked Questions and their answers.
The DAQmx readme states that NI-DAQmx 8.0 for Linux supports the following Distributions:
However, there may be something in the post NIDAQmx on Fedora Core 5 How-To that could help you. There you will also find an explanation as to why we don’t update DAQmx more often.
