nightime screens
Hummer1 wrote:
Sorry, still new to all that.  I guess if you use a type defined control in multiple, and don't make it strict, you could change the properties fo the control at each instance...
Interesting.
Hummer1...back in the closet.
Don't worry about the missed attempt. if you go back 8 years, you would find me hiding and watching myself. Taking the chance and posting even when I was wrong sure helped me.
Ben
Message 11 of 16
(1,562 Views)
Here are the VIs in 7.0 finally
Best Regards
David
Message 12 of 16
(1,533 Views)
David,
Sorry for the delay in getting back to you (too much turkey, etc.).  Thanks for the extra effort.  This info is very helpful for the gauges.  My gauges were laid out before I took over the project and have a decoration background in the cluster along with the gauge.  I have yet to find a way to change the decoration color except in control editing prior to running.  LabView help seems to indicate that that kind of change for a decoration is not available while running.
Again, I appreciate the vi's and the extra effort,
Mel
Message 13 of 16
(1,497 Views)
Hi Mel
No worries, too much turkey is one of the (very few) accepted reasons for going AWOL on this forum Smiley Wink
So your gauges are in a cluster? That means you have to add a cluster case to the code to change the gauges in the cluster. Here's what it would look like:
What is the decoration in the background? Is it picture or a colored background? If it just a colored background you could remove it and change the background color of the cluster via a property node instead.
Best Regards
David
Message 14 of 16
(1,476 Views)
Hi again
sorry, I forgot a line of text at the bottom of my last post:
You can also change the color of decorations in the same way, via property nodes. Here is some sample code.
Hope this helps
Best Regards
David
Message 15 of 16
(1,411 Views)
Hi David,
All this information has been very helpful.  I'm well on the way to solving my problem and should have enough to get the job done.
Thanks for all the help!  Smiley Happy
Best regards,  Mel
Message 16 of 16
(1,388 Views)
