no visa-connect via ethernet
I cant connect to a ethernet connected device with labview, max don´t
find the device (network neighborhood) while tekvisa (tektronics) from
another computer find the device, the ip-connection is up (ping),
switched off xp firewall too tekvisa worked with. max/labview on the
second computer (tekvisa) also dont find it. on the first computer
there is only labview with the ni visa drivers
Any tips welcome
ingo
(4,501 Views)
iwl,
Does your device comply with  the VXI-11 LAN specification? That could be the reason it is not finding it, but you can still communicate with it if you know what port your device is on. Here is a Knowledge Base Article that will walk you through recognizing your instrument in MAX.
Knowledge Base: How do I Configure  an Instrument to Communicate Via TCP/IP in MAX?
Cheers,
-Marshall R
(4,464 Views)
Hi Good morning
I have the same issue,setting up a communication in MAX.
I am trying to communicate via Ethernet with PM6000 power analyser.I have the problem with VXI-11 LAN setup. Also i tried to enter manually the IP address and in the LAN device field i entered the device name but got the error message.
Please give me suggestions on how to setup the Ethernet communication for this Power analyser.
(4,090 Views)
Hi Veeru,
Have you solved your problems? I have same issue as yours. I tried to control Voltecg PM6000. via ethernet. If yes, would you please let me know the solution?
Thanks in advance.
(3,940 Views)
Posted also in Instrument Control board.
(3,923 Views)
