not saving at required frame rate
I want to save images directly to the hard disk during acquisition at a frame rate of 30fps. Although, this is a reasonable, not very high frame rate, im not achieving the frame rate im asking for. The maximum that i can get  is about 14fps for 582x782, 10-bit images and an Ultra-320 15K RPM SCSI hard drive(which is empty; the OS is on another HD). According to my calculations, i should be able to easily save frames at 30fps, as all i am requiring is 17MB/sec, even if we assume that the bus speed is slow.
I am sure that there is something wrong going on. Could anyone please give me some advise or suggestions as how to fix this?
Using: Cohu 7700 Camera Link
            PCI-1428
            Labview 8.5.1
Thanks.
(3,850 Views)
CAn you tell me the calculation u used for arriving at 30fps?You have mentioned 10 bit image.Try saving 8 bit images.
(3,828 Views)
well, it is 582x782x10x0.125x30 = 17MB/sec
why should i save 8bits if i should in principle be capable of saving 10bit images?
PS: ive tried 8bits before and still it didnt work.
(3,826 Views)
It's ok to cross-post to other forums, but please mention it Smiley Wink
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,822 Views)
thanks for pointing it out! 🙂
(3,818 Views)
