not unique table (using DCT)
I am trying to create a dialog box that would pop up and tell my user when a table name already exists in the database.
Does anyone have suggestions?
Attachment.
(2,580 Views)
You would basically check for a given name in the existing table names.  Which is what you seem to be doing in the VI.  So, what is the specific problem you are running into?
-Khalid
PS:  you may want to use a While loop (instead of a For loop) so you can abort searching when a table name is found.
(2,574 Views)
