smtp send message.vi has a wrong send time
I am using labview 7.0 with internet toolkit. When I tried to use "SMTP send message.vi" to send alert message, I got the wrong DATE field. The time is off by a hour.
(3,585 Views)
I would suggest looking at your computer's DST settings - perhaps you have set the clock ahead but not turned on DST. If so, the conversion to GMT and back will not be correct.
Steve Bird
Culverson.com
LinkedIn
(3,582 Views)
The DST settings on my computer is correct. In fact I tried this on many different computers, and they all come to the same result.
Just an another piece of information, when I run "SMTP Email Send Message (Small).vi on the same machine, I got the correct time stamp, but not the "SMTP Email Send Message.vi" and others.
Thank you!
(3,582 Views)
There is a bug in the way the LabVIEW treats daylight savings time in LabVIEW 7.0. Date/Time To Seconds primitive currently ignores it and that is the function used in the email VI.
(3,582 Views)
Hello.  Found this post after having the same problem as the original poster.  On 7.1.1 it is still a problem.  Please see attached gif of a simple workaround.  This patch removes the date from the e-mail info sent and thus leaves the date determination up to the receiver.
(3,417 Views)
Looks like my attachments weren't attached...trying again...
The first gif is the original vi (SMTP Email Send Message Header.vi)
The second gif is this vi with the date info removed.
(3,415 Views)
