number stored as text
Hi~
when write a table to MS Excel, the number all stored as text as you can see green flag on left top corner of each cell, this is cause the fomula in upper cell un-workable.
the code that used to write excel as below:
have you even seen this before? pls advice, thx!
"I think therefore I am"
Message 1 of 10
(5,015 Views)
Hi ELI,
so you write a string array to an Excel range - and now you wonder why those strings are displayed as strings? Really???
Write a 2D array of DBL when you want to store numbers in an Excel sheet…
Message 2 of 10
(5,007 Views)
Hi GerdW,
but the table also contained string like date/ operator name, only the test result is number (show in below).
Eli
Message 3 of 10
(5,001 Views)
Hi ELI,
and what's the problem then?
Write the strings as strings. Write the numbers as numbers. Handle them different!
(You might use even more ActiveX nodes to tell Excel on how to interpret each column of data. I don't think it will be easier this way.)
Lesson learned: Provide all needed information in the first place, not piece by piece…
Message 4 of 10
(4,995 Views)
then it will slow down the process of saving to excel file follow your way.
just like the code I used before, in this way, the string and number can correct show in Excel, but in this way we waste much time to write excel, bcs the table was written to cell one by one.
can we solve this error in LabVIEW? with activeX..
Message 5 of 10
(4,987 Views)
Accepted by ELI2011
There's a hack you can use - after you write the values, read the data from the Value2 property and write what you just read back to the property (so it's write A, read B, write B). I don't know why, but this works. Probably some quirk in how Excel auto-formats types.
___________________
Try to take over the world!
Message 6 of 10
(4,977 Views)
Hi ELI,
Nobody mentioned to write cell by cell. You still can write full columns or even 2d arrays of data - you just have to separate strings from numbers!
There is no error in LabVIEW. And there is no error in Excel. It's an error in your programming!
By now you got two different solutions presented, how much more do you need?
I thought you learned a lesson by now. But you still feed us with breadcrumbs of information with each of your posts: Now you bring the execution time into play…
Message 7 of 10
(4,948 Views)
its amazing, and it really helped!
just read back then write it again, the error disappered.
thank you very much!
Message 8 of 10
(4,928 Views)
not learned a lesson, I am already known these (your suggestion) before! now the issue was solved by tst (Knight of NI).
anyway, thanks for your reply, though it not helped.
Message 9 of 10
(4,914 Views)
lol
Jim
Message 10 of 10
(4,842 Views)
