numeric control, different inrements
I have following question: I want to provide the user with the opportunity to choose in/decrement step size for the numeric control. So the user can choose between stepsize: 1, 10, 100,... How can I do this? Thank you very much!
(2,889 Views)
you can create a property node for the control , then pick Data Range -> Increment and wire a control to it. you can then change the increment on the fly...
good luck
Dan
(2,889 Views)
Hi Aquarel,
You can make use of the Property node of the numeric control for this perpose,i a have attached a example for you ,hope it helps you.
vicky
(2,889 Views)
