numeric control outside limits
I have a numeric control and I have set data entry llimits and selected coerce. It behaves fine using the increment/decrement buttons and when I type data in.
I want to be able to load a preset value read from a text file into the control . The problem is that using a local variable or property node to set the value the limits seem to be ignored.
Is there a way to update the control so it checks the limits or a better way of loading a preset value (the value will be different depending on the informtaion in the text file).
Thank you
(2,789 Views)
Accepted by Link_DP
Use "in range and coerce" before applying the value programmatically and handle exceptions as needed.
(2,782 Views)
Ah great.
I was hoping there would be a refresh/update button or something as I have now got to insert that block and create property nodes of max/min values for many controls.
Thank you for your help.
(2,770 Views)
