numeric indicators to smart array
Ok so I just want to see if I understood everything correctly.
What you want to do is to find a way to put several indicator into a "package" lets say a cluster, array or something similar. The reasons for this is that you want to be able to use that bundle in  you block diagram as a single block instead of having all the indicators laying around the block diagram. Is that correct?
Message 11 of 12
(989 Views)
Yes, correct. But its out of date. I do it with arrays and bundle. And it works correctly now.
Message 12 of 12
(979 Views)
