numeric
How to  make a numeric with variable length ?
And how to make a numeric with EBV formatting ?
Message 1 of 8
(4,239 Views)
Hi Marina,
can you explain the terms "numeric with variable length" and "EVB formatting"?
Can you provide examples for both terms?
A numeric has a variable "length" by default when it comes to the number of digits: you can display just "1" or even "123456789" in an I32 indicator…
Message 2 of 8
(4,230 Views)
1)numerci with variable length is that I have a field inside a command "as input " and it's length is different each time so I need to make this numeric number with variable length or to give it the maximum length "maximum number of bytes"
2)here is the EBV formatting attached
Message 3 of 8
(4,223 Views)
Hi Marina,
1) use arrays…
2) simple conversion:
Message 4 of 8
(4,216 Views)
can you send me the vI itself 🙂
Message 5 of 8
(4,197 Views)
No,
I didn't save it.
But it's rather small and easy to recreate on your own… 😉
Message 6 of 8
(4,181 Views)
In the 12 minutes you sat there waiting for a response, you could have built it up yourself, and likely learned something in the process.  Go ahead and give it a shot.  If you run into issues, tell us what your issue is so we can help you figure it out.  We will not do the work for you.
Message 7 of 8
(4,172 Views)
ok thank you 🙂
Message 8 of 8
(4,158 Views)
