arrays
In the attached file , I want to to how how to correct the logical and runtime error .. I need the upper  enum "s0/s1/s2/s3" to be connected to the lower "s0/s1/s2/s3" .
I want this example to rus as follows .. if session in binary = s2 then s2 outputs 11 so the appended array must have 2 bits for the command "00" and the output from session in binary "11" according to the lower enum
(3,796 Views)
Something like this?
(3,781 Views)
yes can you send me the VI itself but but my labview version is 13.0 ? what was the error in my code ?
(3,777 Views)
Trying to make things way more complicated than they needed to be.  Personally, I would do the combining in the integer format and then change into the Boolean array (like in the attached).
(3,770 Views)
But I need to do it with case structure and for every input 00/ 01/ 10 /11 will go a specific state s0/s1/s2/s3 and in each state will do something else so how to connect the enum with the case structure ?
(3,758 Views)
Hi Marina,
Well, start by wiring the enum to the selector input of the case structure…
(3,724 Views)
Why must you use a case structure?  And why do you need to go through another data type?Does my code not give you the right answer?  My point is that you can do the process on the original enum value and simplify things.
(3,713 Views)
