how to send hex value in visa
 I need to send "0x01 0x02 0x55 0xaa" these hex values in visa write.
how to do this
(3,410 Views)
Hi saran,
just send your data like this:  check.png
Note the display mode setting of the string constant!
(3,398 Views)
Hi GerdW,
Thanks a lot for you reply.
i need Numeric Control to String .
I need to pass values from 0x01 to 0xff.
from Numeric Control ..
How to do that
(3,382 Views)
Hi saran,
simple like this:
Note the display mode setting of the array elements!
You need to learn how to ask for what you really want to know…
(3,378 Views)
Hi GerdW,
if it not Array means .. what to do ?
Single Value . i am passing
(3,362 Views)
Hi saran,
you wrote "0x01 0x02 0x55 0xAA" - that's 4 values to me, not just a single one.
When you have 4 scalar values: use the BuildArray node to put them inside an array. Once you're there you can use my snippets above…
When you have a single "0x010255AA" value: typecast it to an array of U8. Once you're there you can use my snippets above…
(3,359 Views)
