ohmmeter
I assume you mean you can't open the block diagram so you can copy the code.  Hmmmmm, maybe there is a reason for that. Smiley Wink
Kudos for you Crossrulz! Smiley LOL
Message 21 of 34
(2,014 Views)
khalad wrote:
could u please send it again to my email kkk.122@hotmail.com i could not open it when i downlod it .
It wouldn't help since I don't even remember the password I used.  That was a long time ago.
Message 22 of 34
(2,003 Views)
Can you help me with the ohm meter.....
I need also build an ohmmeter for my work
Message 23 of 34
(1,675 Views)
Hi weertss,
Use a voltmeter and a current source!
What exactly is the problem?
Message 24 of 34
(1,660 Views)
It would be best if you just post the text of your homework problem so we know exactly what you are supposed to do.  Then we can HELP YOU write the code.
Message 25 of 34
(1,653 Views)
How do you know that Fluke hasn't hired him to design an Ohmmeter?  😄
Bill
CLD
(Mid-Level minion.)
Message 26 of 34
(1,643 Views)
Fluke?  They probably still use Fortran. 😄
Message 27 of 34
(1,622 Views)
In 2021 Fluke probably uses Fortran.net.
Jim
Message 28 of 34
(1,594 Views)
it's not a homework but a lab to do. And the question that will be a lot beneficial for us is, how can we make our  6/2 multimeter an ohmeter?
Message 29 of 34
(1,561 Views)
This is thoroughly confusing to me.  What is a 6/2 multimeter?  How do you turn it into an Ohmeter?  Maybe turn the dial until it points to the Ω sign?  How does this relate to LabVIEW?
Bill
CLD
(Mid-Level minion.)
Message 30 of 34
(1,554 Views)
