ohmmeter
Me too this is so confusing for me, we need to have a programme that evaluate resistance from tension and intensity that we plug in from our experience. in the steps for our lab, we were asked to initialise a multimeter, then put the multimeter into the the mode of ohmmeter, then take 30 measures of the resistance with the option multiple points and Sample count of the fonction Read.
Message 31 of 34
(1,558 Views)
Ah-ha!  Now we're getting somewhere.  Could you make a new topic so it doesn't get confused with the original one?  Put exactly what you wrote here.  Even though the information is still incomplete, it will at least allow us to ask the right questions now!  🙂
Bill
CLD
(Mid-Level minion.)
Message 32 of 34
(1,546 Views)
So maybe "intensity" = current and "tension" = voltage???
I think we have a language barrier here.  If you start a new post I still suggest you just cut and paste your lab assignment there.  Post in the original language so we can use Google translator and figure out exactly what you are expected to do.  My best guess is it's an exercise to learn Ohm's Law and they need to input a range of Voltages and Currents and then display/graph the calculated Resistances but I can't be sure until I see the assignment.
The good news is that it looks like a really easy program for LabVIEW.  We just need a clear description to help you out... 😉
Message 33 of 34
(1,526 Views)
okey, i will do a new post!
Thank you!
Message 34 of 34
(1,512 Views)
