ok button cluster property node (LV7.1)
Hi folks,
I already found a fix for my issue, but I was wondering if anyone could put some logic to this.  I created a cluster of Booleans using OK buttons because I wanted to use custom text labels, etc.  When I unbundle the cluster, I get the desired booleans.  However, when I created a property node, the Value was Variant - doesn't make sense to me.  What's more, if I wire the property node to a Variant conversion VI (with Boolean type), the output of the property node suddenly becomes Boolean and stays that way when I remove the conversion VI - makes even less sense.
Why are OK Buttons somehow different from other Booleans when used in a cluster?
The fix I went with was to create a bunch of square LEDs with text, turned those into controls, and then put them in a cluster.
Michael Tracy
Synergy Microwave
(3,709 Views)
Accepted by SynergyMike
The Property Node was a Variant because the "OK button" is set to a latching type. You shouldn't read/write to latching type buttons programmatically, because a race condition is bound to happen. Your issue didn't concern the cluster.
Richard
(3,700 Views)
Thanks - I forgot about those pesky button "latch" actions.  I normally remember to get rid of them when using single buttons...
Michael
(3,659 Views)
