ā09-04-2017 11:51 AM
i cannt write data in opcua 2017 client and see this error
by labview 2016 i write data easily
and with other opcua client i can write data
hep me please
ā09-04-2017 01:42 PM
If it works in LabVIEW 2016, but not in LabVIEW 2017, I have two (three?) suggestions:
I'm really hopeful that you will not need to use the third solution.
ā09-04-2017 02:39 PM
Is LabVIEW 2016 allowed through the firewall and LabVIEW 2017 blocked?
ā09-04-2017 08:27 PM
1. You can use the Forward Browse.vi to get the information of the node. In the browse result, what is the node type?
2. What is the OPC UA server? Is it a 3rd-party server?
Thanks!
ā09-04-2017 11:22 PM
1-all things is ok except write data
2-yes server is twincat opc server but in labview 2016 and uaexpert opc client all things is ok
you can see attach files
ā09-05-2017 03:52 AM
You can use the Forward Browse.vi to know what is the node type of the assigned node as follow.
The status "Bad_WriteNotSupported" is often caused by the node type is unsupported. So we'd like to know the node type.
Thanks!
ā09-05-2017 08:08 AM
i do it
and attach file
ā09-05-2017 11:00 PM
all windows firewalls is turn off
ā09-06-2017 10:19 PM
Is it possible to reproduce this phenomenon on my side?
Thanks!
ā09-28-2017 05:23 AM
HI, I have the same problem... LabVIEW 2016 can write the tag, while 2017 cannot, with the same BadWriteNotSupported error.
The firewall is disabled, and the result of the Forward Browse for the given tag is:
reference type: Organizes
node ID: ns=2;s=iTestAliases.Pippo
browse name: Pippo
node class: variable
node type: DataItemType
Thank you for helping!
