Hi Lacoule,
make a copy of the link to LabView you find in the Start Menu, then open its Properties. In the Destination text box you'll see something similar:
"C:\Program Files\National etc...\LabView.exe"
Add the name of your vi to the end of the line:
"C:\Program Files\National etc...\LabView.exe" myviname.vi
In the From: text box below, write the name of the directory where the vi is located (enclose it in double quotes "" if the name contains some blank char).
Finally, add the new link to Programs -> Automatic Execution (or equivalent) in the Start Menu.
Probably, you can do the same with your utility program.
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
