open vi reference in executables
My application requires to run two sub vis in parallel , Even though the VI is running the executable is showing reference. I am using open VI reference to open the sub vi from the main vi please reply..urgent
(2,833 Views)
I guess your problem is related to the vi path. You should create some indicators for debugging. One indicator for the path, and some indicators on the error output. Then you can build your aplication for testing.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,831 Views)
If it is related to using Current VI's Path, then please read this article: Why Does My Executable Not Work When Using the Current VI's Path Constant?
I don't understand this sentence: "Even though the VI is running the executable is showing reference." Can you please clarify?
Message Edited by smercurio_fc on 04-24-2009 09:33 AM
(2,820 Views)
