openning a 250 MB file into a U8 1D array
I am working on a program that views a data format that labview doesn't handle itself. So to decode the data I open the file with red text file, but I cannot open anything larger than a 2Mb file. When I do I get an out of memory error.
Any hints on how to view large files
- there is always an easy way, but it is always the hardest to find
(2,667 Views)
Can you post a sample of the data and your vi. 2mb seems awfully low as a labview limit. How much memory does your computer have?? Do you need labview to hold the entire result in memory??
(2,655 Views)
Hello Beaton,
I would reccommend looking at this Developer Zone document as well:
-Justin D
(2,628 Views)
