or gate signal to timer before stop in while loop HOW?
One simple way to do it would be to replace your sting indicator with a single button dialog.vi with the output of your select wired to the message input.
P.S. The word 'your' is improper in your message. It probably should read "You are" or "you're".
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 11 of 16
(1,221 Views)
Please be understanding as i am a labview virgin and really am not entirely sure on certain protocols.
How would your suggestion give me a time delay?
cheers
Message 12 of 16
(1,214 Views)
Accepted by topic author metsystemalex
HAHA,  We understand.  Understand that you are talking to a bunch of Professionals....
I think that you'll find that this is a very good support group.
Here is some code that may be what you are looking for.
Ben Yeske
Message 13 of 16
(1,198 Views)
BRILLIANT. THAT WORKED A TREAT. YOU JUST HELPED AN ENGLISHMAN FROM A FATE WORSE THAN DEATH (WELL MAYBE NOT) BUT CHEERS ANYWAY.
THANKS TO ALL WHO REPLIED
CHEERS
Message 14 of 16
(1,190 Views)
You probably don't need that true/false case structure. The loop will not finish until all code is finished within. So until the user presses the 'ok' button the loop will not finish and not exit.
P.S. Winner. Not Weiner. Smiley Wink You don't want to call the user a sausage or piece of meat.
Message 15 of 16
(1,184 Views)
kudos are also given for subtle humor...  :smileywink:
Message 16 of 16
(1,177 Views)
