ora 12154 tns could not resolve the correct identifier specified
I am facing the following problem:
windows 7 64 bits, labVIEW 2012 32 bits, oracle client 10.2.0.1.0 (32 bits).
I created a DSN from Data Sources (ODBC) (the 32 bit version of this which is %windir%\syswow64\odbcad32.exe) pointing to an Oracle 10g instance.
I test the DSN through this (ie. Data sources (ODBC) and the connection is successful (which means that the tnsnames.ora is correct).
I use the "DB Tools Open Connection.vi" in order to get connected to this database passing as parameters the DSN above, the user name and password.
I get the error:
ADO Error: 0x80040E4D
Exception occurred in Microsoft OLE DB Provider for ODBC Drivers:
[Oracle][ODBC][Ora]ORA-12154: TNS could not resolve the correct identifier specified
any help will very appreciated
thanks in advance
(4,944 Views)
What is the connection string you are using?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,908 Views)
Hi Mike,
I was reading in the chapter 3 of the Database Connectivity Toolkit information related to how to connect to different database types. If the database is ODBC you can create a DSN, and this chapter shows how to do it. Also, If your database is ADO or OLE DB, you can set a UDL to connect to it and this chapter also shows how to do this.
I recommend you to check this manual, chapters two and three for your purposes.
You can get this manual here:
http://www.ni.com/pdf/manuals/321525c.pdf
(4,905 Views)
Accepted by JustinianWagner
hello everybody.
I already solved the problem  (working until late Saturday).
the solution was to install the latest Oracle client, namely: Oracle 11g Release 2 CLIENT for Windows 32 (11.2.0.1.0).
Now everything runs OK.
I also tested it in Widows 7 32 bit (the same .vi and the same Oracle client). It also runs OK.
Thans a lot.
(4,895 Views)
