order analysis, executable and LabVIEW 8.0 RT
Hi Khallis,
Please reply with a simplified copy of your program that I will be able to run on my computer. i.e if you have any hardware code please delete them and create a very simple OAT code that can be used to reproduce the problem. I will run it here on my end to figure out how to get the exe to work. Have a great day!
Prashanth
Message 11 of 14
(1,538 Views)
Dear Prashanth,
Please see the attached VI. It has only sub VI. Try using this VI to create your executable
Kallis
Message Edited by Kallis on 08-10-2006 06:58 AM
BR
Message 12 of 14
(1,532 Views)
Kallis,
Thank you for the information.  This is indeed a peculiar problem.  I am currently reproducing all of the behavior that you have described and have moved to the phase of finding why these problems are occuring.  Firstly, the Order.dll was put into the system32 directory.  Dependencies that are located in this folder are not automatically downloaded to the real-time when deploying the executable.
I am currently looking for a work around for using executables with the Order Analysis Toolkit.
Steven T.
Message 13 of 14
(1,505 Views)
Thanks a lot Steven,
Good Luck.
Kallis
BR
Message 14 of 14
(1,430 Views)
