order of transfer functions
This problem puzzles me...
I have a physical system which I try to model by describing every component by its tranfer function.
However, I noticed that the order in which I place these components plays a role in the output that is generated by the vi.
From a theoretical point of view, the blocks in serie might be replaced by an equivalent transfer function, i.e. their product.
But I noticed that a different sequence of the blocks, (but the same glabal transfer function) gives different results.
To keep the link with the physical system I would like to keep working with the seperate components.
I included a file to illustrate the problem: Three times the same open loop transfer function, but two different results...
Are there recommendations on the order I should put them in? And what is the cause of this?
Thanx,
Elie
(2,631 Views)
Floating point arithmetic itself has rounding issues that are very well known and are an accepted issue. Here is a resource for more info.
That might be the source of your discrepancy. Essentially the operations could each have their own different rounding errors, which would result in a different output when stacked up in different orders.
Cheers
(2,624 Views)
