oscillscope project
Hey Ray ,
Ray could you please save it in LV 8.2 ?
btw are u getting my emails on ur work email address ?
LV 8.2
Message 121 of 401
(1,482 Views)
Here its in LV8.2....
Mathan
Message 122 of 401
(1,469 Views)
Thx Mathan.
Ray i did run it , it is acquiring Data now but still connot stop it !!!
I have a weird question , how the selection is going to measure Force signal if i select force and not an EMG signal ? i mean how it is going to go to the Force one ? should we make a change to Index array ?
Message Edited by kmous on 07-24-2008 08:15 AM
LV 8.2
Message 123 of 401
(1,459 Views)
I got your emails, thanks.
I will look at the code.  Sorry about posting it in LV8.2.
R
Message Edited by JoeLabView on 07-24-2008 10:11 AM
Message 124 of 401
(1,451 Views)
I meant sorry about posting it in LV8.5..  😉
My mind is still on vacation mode LOL! 😄
Message 125 of 401
(1,435 Views)
ahahahah , dont drink too much on vacations RAY 🙂 hope u had fun !!
LV 8.2
Message 126 of 401
(1,432 Views)
Hi kmous,
I rememebered an important item.
When I modified the program, I just added the waveform selection portion, but did not implement the actual selection algorithm, which is why you do not see a difference.  I thought you would be doing that part.
I will have time this afternoon to make the rest of the changes.  Sorry about the confusion.  I was tailoring this to be a "training" exercise as well.  😉
I'll be back soon.
R
Message 127 of 401
(1,417 Views)
Thank you MAN !!
I am trying since this morning to figure out how to add the Oscilloscope check box in the selection part , connot do it.
I tried to add another type to the Unbundle by name  , and another tab for build array but  did not  work out , is that how i do it ? because the program should  measure 3 things  u know!!
One more thing how the hell can i add more 5 channels available ? in Denis algorithm we have 10 available from 0 till 9 , is there somewhere in properties od Channel must add ? or the loop ?
LV 8.2
Message 128 of 401
(1,415 Views)
I'm back 😉
You should be able to simply adde them within the array of clusters.
I will change the architecture so that you can have a variable amount of channels.  After making the change, remember to right-click and save as default otherwise they will be gone the next time you open your vi.
I'll do the changes in LV8.2.
R
Message 129 of 401
(1,409 Views)
Try this version.  I could not run it because I do not have the DAQmx resource... although I could probably simulate it...  Which DAQmx devices (model numbers( do you have installed?
R
Message 130 of 401
(1,397 Views)
