oscillscope project
I will try it , thank you for the call 🙂 at the beginning did not that it is you :S sorryyyyyyyyyyyyyy
it is NI 9205 analog input on cDAQ-9172
I will try this version and let u know what's happening !!!
Merci Ray
LV 8.2
Message 131 of 401
(1,261 Views)
 No problem..
If this works, we can then add the oscilloscope selection.
The only thing that may be "weird" is the indexing of the 2D array before the EMG filter or Force.  Try both to see if the proper one(s) are displayed.  If not, it is an easy fix.
R
Message 132 of 401
(1,261 Views)
Bonjour Ray ,
I tried 2 things :
1- to acquire only channel 0 as EMG,  i tried it  under highlight exec, but i saw that it does not go into EMG case , it goes to the force one !!
2- to acquire 2 channels 0 , 1 both EMG , i will attach a graph for that ., the output voltage is negative (betwwen -6 and -4 weird).
3- to acquire only channel 0 as Force , i tried it also under highlight exec , it goes into both of them , once emg , once force.....
what do u think ?
LV 8.2
Message 133 of 401
(1,243 Views)
I will modify the VI so that it stores raw data that I can use and experiment with.
I need to take care of a couple of things this morning and will do it immediately after.
R
Message 134 of 401
(1,237 Views)
kmous,
Run the attached VI and send me (my email) or attach to this thread the file that will be located in C:\rawData.dat
The change was quick, so I did it immediately.  That will allow me to test the code with real data.
R
Message 135 of 401
(1,234 Views)
I sent you an email ! 🙂
LV 8.2
Message 136 of 401
(1,220 Views)
I will look at it soon.  Thanks 🙂
Message 137 of 401
(1,205 Views)
Got it.  Thanks.  I will look at your last post (description).
R
Message 138 of 401
(1,196 Views)
I forgot to ask..
What were your settings for the data file?
R
Message 139 of 401
(1,189 Views)
well i am not sure if the output is the right one , but output file must be a binary file , and must contain a header that tells me the sampling rate and the channels i am acquiring (emg/osc/force) for each one.
did i answer ur question ? 🙂 hope I did !!
Btw enjoy ur weekend
Thnak you Ray
LV 8.2
Message 140 of 401
(1,180 Views)
