output continuous signal to sound card using Simulate Signal Express VI & Play Waveform VI but sound has glitches
Hi! I'm trying to output a signal (e.g. 440Hz sine wave) to the computer sound card using the Waveform Generation VIs and the Simulate Signal Express VI as seen in the image below (taken from https://www.ni.com/docs/en-US/bundle/labview/page/sound-vis.html). However, I am unable to get a continuous sound output! The sound output has glitches/stops/interruptions. Is it because the sound stops after every loop? I'm not sure what's the problem! Please help. Thanks!!
(P.S. I have seen labview examples such as Continous Sound Input.vi but the examples do not use the Simulate Signal Express VI which I would like to use. Also, there is no problem with my sound card as it produces a nice continous sound ouput when I run the Generate Sound.vi Labview example. Thanks!)
(3,670 Views)
The problem is the express VI. It is not designed to provide continuous sound output. In addition, you are generating a new waveform with each iteration. There will naturally be a break in the sound with each loop.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,648 Views)
