output from a for loop in mathscript
Hello there! What I am trying to do is to produce a semi-circle pattern composed of separated rectangles using IMAQ DRAW, please see attached slide.
The pattern will be later projected on a screen. as the offset S changes, the number of rectangles changes. so I thought it would be easier using a for loop in mathscript, please see attached VI. but the problem is the outputs of the MATLAB script only store the last number it gets from the for loop. I tried to change the data type of the outputs into 1-D array, but it did not help either.
Could anybody please have a look at the VI and give me some suggestions? I have been stuck for days!
Thank you very much!
Brian
(4,561 Views)
Accepted by topic author Raul6128
Why do you need a Mathscript node to calculate a simple circle?
Why not use basic LabVIEW code? Why not employ polymorphism to get rid of loops as much as possible?
(Just following the formulas given in your PDF. Because of square and root functions it will only work for one quadrant.)
(4,546 Views)
Hi GerdW,
Thank you very much for your suggestion, it makes things much easier.
I 've only got one problem to fix. Since I need to project the pattern on a seperated computer screen, I guess I have to use the IMAQ DRAW function to implement it. but the problem is the data type of these two terminals are different.  The coordinate of IMAQ DRAW is 4 elements, and the outcome from the bundle cluster is 2 dimensions. Do you have any idea how to pass the data from the bundle to the IMAQ DRAW in 1-D array?
Many thanks!
Brian
(4,527 Views)
Hi Raul,
In my snippet I calculate the X and Y coordinates on the diameter of a circle. When you need more/other coordinates for IMAQ you need to calc them. Use my snippet as a starting point…
As I don't have IMAQ installed I cannot check what kind of data you need!
(4,522 Views)
Thanks! the problem has been solved.
Cheers,
(4,504 Views)
