> i was working on using an external *.exe to encode some data and i
> need to take a dir listing in so that i can apply the encoding to
> certain files, but i am having a little diffuculty in in outputting a
> text file from which to scan, i have
> i am using labview 6, and the main vi elements i'm using for this
> proccess is the list dir vi index array vi and write chars to a file
> vi, but i cannot get the file names on a new line for each one, they
> are all after each other with one space....
> i know in text based programing you can use \n or similar to solve
> this, but i am at a loss here with labview
> if any one could help i would be most grateful
The string palette has constants for different linefeed, carriage
return, or the platform adapting en
d of line. If you add this
string character between names, that should get you started.
Greg McKaskle
