pam.vi
I don ´t see the coersion dot. Anyway, Could you explain me the use of the pulse shaping filter? It is said to be used to filter the data streams before modulation onto the quadrature carriers.
Greetings
Message 11 of 12
(838 Views)
I have one more question, as you know I am using a DAQ to send and receive the modulated signal, so the question is for a PAM modulated signal which has an analog signal (information) and a digital signal (carrier) which daq ´s channel do i have to use? The digital ones or the analog ones?
Greetings.
Message 12 of 12
(838 Views)
