parallel port
Hi all,
I hope someone can help me.I would be very thankful! I've gott a
question/problem. I've programmed a VI in LabVIEW 5.0 and that writes
bits to the parallel port with the Out Port VI. It works good at my
computer. But when I'm installing it at another computer I get an
error message which says: " Capability not supported. VI'setprog1.2(my
VI name)'was stopped at node Ox1BC of SubVI 'OutPort VI'".
I think this has got something to do with the parallel port(e.g. that
the VI doesn't see the parallel port). Am I right? And has someone had
this before? Both systems are runnning at Windows NT (2000).
Greetz,
JJ
(2,882 Views)
Hi JJ,
I recommend to simply search for "parallel port" on this discussion forum - you will see that your question is already answered x-times.
Independent of that have a look at: http://zone.ni.com/devzone/explprog.nsf/webmain/49664743DED6F1DA862564BC004E3A7F?opendocument&node=DZ52058_US
If you need more support mail to werner.hasche@web.de
regards
wha
(2,882 Views)
