part one to be executed and after certain time part two to be executed
Divya,
In your Amp Tester.vi, the output of High_Wave(SubVI).vi, which is a constant 5V is connected to DAQ Box Outputs2 indicator. The Make waveform.vi is called before High_Wave(SubVI).vi. Kindly look at your block diagram
Satish
Message 21 of 28
(919 Views)
Satish,
I did so because I wanted to split both the parts, i.e. generate the signal for 7 seconds, then route the signal flow to both the remaining signal genration( for about 15 seconds) and also the second loop. To be more clear, execute both the loops simultaneously.So I tried generating the pulse waveform and then leaving the Output 2 ON i.e. a DC waveform ,I simultanously tried executing the second part(Bottom part) of my program.
And about the previous post, I checked with my scope and I'm didn't find any error with it too..tried aseveral scopes too but still I dont see any output waveform.
U want me to trigger the scope internally before outputting the waveform??
Divya
Message 22 of 28
(902 Views)
Hi Patricia,
I've attached the part in the previous post. Output 2.Vi..
I'm not getting output from this loop.
Divya
Message 23 of 28
(901 Views)
No attachment.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 24 of 28
(898 Views)
Attachment Attached
Diya
Message 25 of 28
(894 Views)
Divya,
In the Output_2.vi, I am able to see the waveform indicator getting updated with proper waveform (refer screenshot). I don't have a DAQ to test the output. Are you getting this waveform in the indicator? The only change I made is, I used constant values (refer to rose coloured comment in screenshot) instead of the output of random period.vi (since you didn't attach in your post). So kindly make the change and check.
Satish
Message 26 of 28
(875 Views)
missed attachment in my previous post
satish
Message 27 of 28
(873 Views)
Thankyou Satish for the Help.
The issue is fixed now.
Diya
Message 28 of 28
(841 Views)
