passing complex structure array to a DLL
I tried searching the functions in my version of LabView for "DSNewPtr", "CIN" and "Code Interface Node" and didn't get any results. I also found this page:
External Code for LabVIEW - CIN / DLL - Starting Point
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LubSAE&l=en-US
This page states that there are 5 steps to use CINs and that "The base package does not provide the tools to do step 4."
Message 11 of 14
(1,761 Views)
CINs are old legacy technology. They are not even supported on the newest LabVIEW platforms (64Bit) and LabVIEW doesn't come with the necessary tools to create them for some versions.
But interfacing DLLs from the Call Library Node is AFAIK not limited to any specific LabVIEW version. I might be wrong here though.
Rolf Kalbermatter  My Blog
Message 12 of 14
(1,758 Views)
I can definitely use a Call Library Node with my version of LabView, but if I need to use "DSNewPtr", as suggested, I can't seem to find that function.
Message 13 of 14
(1,755 Views)
Old thread, but may be of use to others who come across this problem.
DSNewPtr is a LabVIEW.exe function: http://forums.ni.com/t5/LabVIEW/array-pointer-from-dll/m-p/1217453#M519958
Message 14 of 14
(1,547 Views)
