path array
The problem I'm having is with array of paths. I include a zipped folder with some directories and a vi I use to retrieve information from the folders. The vi keeps returning two cells with empty path without any reason that I can think of. I have tried several solution but non of them work yet. The problem is affecting other section of my project.
Please any idea on what's causing this problem?
(3,662 Views)
(3,654 Views)
Hi
Are you talking about the image attached ?
Regards
Paul
(3,648 Views)
Yes. I expect to see not a path instead of a blank.
(3,641 Views)
Accepted by aderogba
Hi
See the attached solution, you had a shift register missing in the inner loop, therefore all the not a paths you were inserting were not being passed around, only the last not a path on each row would be seen.
Regards
Paul Rawlinson
TBG Solutions
UK
(3,623 Views)
