pdf exaprom
I have one problem according this fine tool.
I wan't to make pdf report and i have problem with aligning data table and graph picture.
Example of report shows how it shouldn't be. I would like to have table and graph in aligned in same hight on same page.
I'm out if ideas so if somebody can help me i would be very grateful.
(3,751 Views)
Accepted by Schime
First, you have to insert your image with "position = Right (textwrap)".
Second, you have to insert the table.
I tried with a newer version of Exaprom PDF, but this is supposed to work with the older version.
(3,717 Views)
Thank you for your help. It's working perfectly.
(3,690 Views)
