peak detection
Hello all,
I would like to find peaks in my signal but I am looking only for big peaks. I am trying to use peak detector but threshold in this  vi is from 0 and that is not working for me because my signal looks like in the picture ( red signal ) . As we can see there are around 10 peaks but tool found 1236.
So question is how to find only big ones.
Best regards
Message 1 of 12
(6,855 Views)
\vi.lib\measure\mamon.llb\Waveform Peak Detection for 1 Chan.vi
Message 2 of 12
(6,833 Views)
how to find it ?
Message 3 of 12
(6,829 Views)
Hi pablo,
when you need help with your VI and your data you should attach your VI and your data!
(You know we cannot debug images with LabVIEW!)
And please define "only big ones" by providing an example waveform together with your expected result…
Message 4 of 12
(6,819 Views)
Hi GerdW
I am using hardware input so i don't know if you can debug application.
I am attaching my vi and picture.
Best regards
Message 5 of 12
(6,811 Views)
Hi pablo,
we also need the data shown in your images!
Run your VI until you see nice plots in your graph. Then stop the VI.
Now call edit menu -> set all values to default.
Save the VI, attach it again…
Message 6 of 12
(6,805 Views)
Data will be different for every run but for debugging purposes we can use this one
Message 7 of 12
(6,802 Views)
Accepted by plpablo
Hi pablo,
you also should try to get rid of (unneeded) ExpressVIs!
Use IndexArray instead of SplitSignal.
Use BuildArray instead of ToDDT and JoinSignal!
See this:
Message 8 of 12
(6,794 Views)
Can You attach VI ?
Message 9 of 12
(6,790 Views)
No, didn't save…
It's just the PeakDetector, applied on your data.
Message 10 of 12
(6,783 Views)
