peak detection
Ok works perfect, thank you. can You explain to me why width is 125 ?
Message 11 of 12
(893 Views)
Hi pablo,
the PeakDetector works "number of samples"-based, so it looks for larger/wider peaks. (I guess this is explained in the LabVIEW help more accurately.)
That's also the reason why I scale the location results by the dt of your data to convert from "number of sample" back to time scale…
Message 12 of 12
(888 Views)
