peak value over a given time period?
Hello.
We are a group of students who are looking for a way to use our blood pressure measurements in labview.
What we want to do is to have labview display the peak value when our curve tops the first time, then hold this value for some seconds.Then show the new peak value
and hold this a few seconds and so on.
Right now we can get it to show the peak value but it updates all the time.
We have tried different approaches but none of them seem to work.
we have attached our project as it is right now. maybe someone can help.
Thank you.
Message 1 of 17
(3,377 Views)
hello
it's possible to change your file in LabVIEW 2009
Message 2 of 17
(3,374 Views)
Should be labview 9.0 now
Thanks for replying so fast
Message 3 of 17
(3,369 Views)
Is this what you are looking for?
Nitzz
(Kudos are always WelcomeSmiley Wink)
Message 4 of 17
(3,368 Views)
Not exactly,
We would like the program to display the peak value over a period of 3 seconds continuously, by that we mean we would like one peak value for each 3 sec interval.
we hope you understand what we mean
and thank you for your help.
Message 5 of 17
(3,362 Views)
I think this is what you are looking to do. If you change the peak timeout on the front panel it will change how often the display updates.
Tim
GHSP
Message 6 of 17
(3,342 Views)
Accepted by topic author kagemand1234
After reading your post a little more closely and looking at the other suggestion on how to solve your problem I think this is what you want to solve your problem.
Tim
GHSP
Message 7 of 17
(3,336 Views)
that worked out perfectly.
thank you very much 🙂
we will take a look at it now and then try to find the valleys aswell.
Message 8 of 17
(3,317 Views)
I sent you a message about this. If you have other questions you should use the board. I get notices that you have responded here I do not get an email when you private message me.
Tim
GHSP
Message 9 of 17
(3,283 Views)
Can you please post the last VI in LV 2009?
Message 10 of 17
(3,214 Views)
