peak value over a given time period?
Here you go.
Tim
GHSP
Message 11 of 17
(794 Views)
Weird...I still get same error code...
Message 12 of 17
(790 Views)
What Error Code are you getting?
Tim
GHSP
Message 13 of 17
(788 Views)
See attached
Message 14 of 17
(786 Views)
I have posted this method before but it's not very popular, BUT... If you are using a Chart, and the "time period" in which you want to capture the peak value is not longer than the Chart History Length*, then you can read the array from the chart Property Node "History Length" and just use Array Min Max to find the Max. Remember that we get that "free array" with charts.
*Let's say your loop takes 100mS, and your Chart History Length is set to 4095, that's . This gives you ~6.8 miuntes of data in which to grab the peak. Need longer? Make the Chart History Length longer, or store the highest number in each given chunk of 4095 samples.
Richard
Message 15 of 17
(784 Views)
Let's try again
Tim
GHSP
Message 16 of 17
(781 Views)
That worked. Thanks ! Smiley Happy
Message 17 of 17
(775 Views)
