pgia
I am acquiring a signal using USB 6281, which comes with a programmable gain. I wanted to know how to modify the gain. I looked into DAQmx channel using which I can set AI Max and Min. Is the gain adjusted when I modify these values?
Navi
(5,284 Views)
Accepted by navinavi
Yes it does. Set the min and max and daqmx will select the range for you. You can use a property node to read the range which has been selected.
(5,274 Views)
Thank you!
(5,264 Views)
No problem (just in case you are very new, you can click Kudo to give thanks where an answer helps)
Pleased to help,
Michael.
(5,257 Views)
How exactly do I use/add the property node here? I was not able to add property node via the create option.
(5,120 Views)
from the DAQMx Pallette drop a Channel node. then from the LabVIEW Help:
Analog Input:Maximum Value Property
Short Name: AI.Max
Property of DAQmx Channel
Specifies the maximum value you expect to measure. This value is in the units you specify with a units property. When you query this property, it returns the coerced maximum value that the device can measure with the current settings.
So My first answer was a slightly incorrect.  I just tried this and sure enough if i set AI.Max to 3.2, then read AI.Max it reads 5.  As 5V is the smallest range my particular device can use to read 3.2V
I hope that helps,
Michael.
(5,115 Views)
