ph monitoring
I am going to do my mini project on pH monitoring using lab view.May I get some suggestions how to proceed further.
(2,808 Views)
Hi deepika,
Your question is rather generic so you get a generic answer:
  1. Buy a pH sensor.
  2. Connect it to a (DAQ) device able to read its output signal.
  3. Use LabVIEW to get the reading of that (DAQ) device.
  4. Do anything you want with the read values…
(2,800 Views)
@GerdW wrote:
Hi deepika,
  1. Buy a pH sensor.
The red part can be dangerous !
Raw pH sensors need a high impedance input! Not all DAQs have that!
Greetings from Germany
Henrik
LV since v3.1
(2,780 Views)
Either get a pH sensor with in-build circuitry to offer a low impedance signal or you will need to buy a pH meter and interface with that (USB, RS-232...)
(2,769 Views)
