10-27-2008 08:25 AM
The Extract Single Tone
Information.vi you find that the data is apparently derived from a complex FFT. I think the
phase you get from an FFT is related to the reference function. I quote
from Chapter 4 of the LV Analysis Manual:
"The phase is relative to the start of the time record or relative to a single-cycle cosine wave starting at the beginning of the time record. Single-channel phase measurements are stable only if the input signal is triggered. Dual-channel phase measurements compute phase differences between channels so if the channels are sampled simultaneously, triggering usually is not necessary. The phase is the arctangent of the ratio of the imaginary and real parts and is usually between π and –π radians, or 180 and –180 degrees."
Amp and Phase spectrum seems to be the cause of it. Its always important to pass the expected data form to these functions. And I imagine we're not passing or understanding the output of the amp and phase spectrum properly. However, from the help, I couldn't work it out.
Any ideas?
Kind Regards,
10-27-2008 09:15 AM
The LV Analysis Manual sounds like a useful document. I tried searching for it on the NI site but couldn’t track it down, any ideas where it's hiding?
Thanks. Ian10-27-2008 12:12 PM
11-11-2009 04:24 AM - edited 11-11-2009 04:25 AM
09-16-2010 07:16 AM
hi,
I need to see extract single tone information.vi block diagram.could u send the vi.actually it is locked in my labview.please sned it ASAP.i need to know how they are calculating the amplitude and phase from time domain signal.it is required urgently for me
regards
mohammed
