physical channels
hey , i have a problem with physical channels in the DAQ assistant .
I have pressure sensor , torque sensor  and a flow sensor that i want to test them.
in other hand , i have the DAQ(USB-6001) , labview 2012 and NI-DAQmx 15.0.1 .
When i want to put analogue input in the DAQ assistant , the physical channels channels appears in "voltage ,temperature, current .." but don't appear in "pressure , torque and some others "
What do you think is the problem ?
Message 1 of 15
(4,579 Views)
I think the "problem" is that you are using the DAQ Assistant, which is designed as a "simple" approach to DAQ, hence is unsuited for even slightly-more-complex tasks.  Read this excellent White Paper and replace the DAQ Assistant with a small amount of real DAQmx code to do exactly what you want to do.
Bob Schor
Message 2 of 15
(4,569 Views)
My opinion is that the inexpensive device does not support those measurement types. That could be because it lacks built in excitation, etc.
Message 3 of 15
(4,560 Views)
I think you need to use a custom scale - I think the pressure/torque options are for devices that have a built-in bridge circuit. Since you're not using one of those devices, you need to read in the voltage from the sensors and use a custom scale to convert from Volts to Pressure/Torque/Flow.
(blog)
Message 4 of 15
(4,548 Views)
All of your sensors are voltage measurements.  You need to know how to convert those volts into your unit of measure.  The other options are just there to make things easier for you.  it's still generally a voltage measurement.
Message 5 of 15
(4,544 Views)
please can you tell me where exactly i should focus in this paper ? or can you give an example on how to convert from voltage to pressure or torque? i am new in this software.
thank you
Message 6 of 15
(4,497 Views)
LabVIEW has 100's of examples built-in. Go to Help -> Examples and search for DAQmx. You can probably search for 'custom scale' and get an example for that too!
(blog)
Message 7 of 15
(4,486 Views)
The details for the conversion will be in your sensor documentation. You have to read that first and understand it. After that, it's generally basic arithmetic. You should not be new to that
Message 8 of 15
(4,481 Views)
i tried to create a virtual channel and look what happened .... 12183737_10153385431178020_1509519534253030576_o.jpg
Message 9 of 15
(4,388 Views)
No, the device does not support a bridge measurement. That is the same reason you can't use the DAQ Assistant. You were told to create a voltage measurement.
Message 10 of 15
(4,364 Views)
