pic 16f877 rs 232
i think i have dowloaded this programme from here!
Message 11 of 39
(2,780 Views)
I can understand why you are confused.
Whoever wrote that didn't know what they were doing.  The local variables and stacked sequence structurs are painful to look at!  Several items in there such as comparing a boolean control to a boolean constant are straight out of the Rube Goldberg thread.  I like how the one stacked sequence structure (in frame1 of the big stacked sequence) uses 6 frames to send 1 byte at a time to the serial port.
Message 12 of 39
(2,777 Views)
I agree. That is a very bad example. How did you actually find it? Don't even bother with it - just delete it.
Try the attached VI and see how far you get.
Message 13 of 39
(2,770 Views)
wowwww !!!!
thanks smercurio_fc !
i have just trie it and it realy works beautifuly !
i´m going to analise how it works !
you are right it seems mutch more simple !!!
thanks again.
Message 14 of 39
(2,746 Views)
hello !
the programme is runing very well !
a can separate in a string , 8byts, whith 8bits !   (some experiences)           y     x
From the pic i´m sending 4 byts , 2 for eatch  ADC! a read something like (03 ;255) = 5V!
I have tried meny solutions but don´t seame very estable!tried numeric operations ......x+(256*Y)
how can i ad this two numbers to be with 1024 ?? am i going on a wrong way????
Message 15 of 39
(2,722 Views)
I'm sorry, but I did not understand a single thing you said. Can you please rephrase, or provide a concrete example?
Message 16 of 39
(2,719 Views)
Sorry !
well what  i was triing to say ,was that a´m sending data from ADC .The ADC has a 10bit resolution!in serial comunication ,i can only send 8bits string.
if i want to read 10bit from ADC , i must send 2 byts ( 2x8bits) right ???
when ADC is reading ex: 5V he must have 1024 positions(10bits)!In Labview , i can read 2 byts the first(03), and the second (255).
I have tried to add this 2 byts in order to have  1024 ( 10 bits). Ex:
                                                           first byte (x)       second byte(Y)
                                                            (03)                    (256)                      X+(256xY)=result(1024)
this aplication works,but it doesn´t seme very stable!!!!
my question is :how do i add this 2 byts, or there is a more simple way!
am i taking a wrong direction???
I´m realy sory about my ingles!!
Message 17 of 39
(2,712 Views)
Yes.  You can use the join bytes function.  You wire in two U8 bytes and out comes a single U16 byte.
By the way, a byte can only go up to 255.  And if your first byte is the high byte of 03, then it is (X*256)+ Y = 3*256 + 255 =1023
Message Edited by Ravens Fan on 07-09-2009 03:49 PM
Message 18 of 39
(2,709 Views)
A Type Cast would give you the same thing. Smiley Wink
Message 19 of 39
(2,700 Views)
Dohhh! Of course.
What got me on the path of the join bytes was that other thread where the poster was trying to decipher the byte but said that the byte of interest was slipping between the first and second byte.
Message 20 of 39
(2,690 Views)
