pico logger
I am making test temperature for a motor using a pico logger TC-08. I am actually via this program saving the values of temperature every 1 minute in the current time.
After waiting 20minutes, I am supposed to start a boucle where i compare the value of temperature tooken at 20min with those tooken at 0.
To be simple I have everytime to compare, T20, T0/ T21,T1/T22,T2/T23.T3... with always a delta T equal to 20min.
I didnt find a way to get out the values already tooken... I'll join my VI
All help or suggestion is most than welcome
(3,712 Views)
https://forums.ni.com/t5/Example-Code/PicoTech-Picologger-TC-08-Thermocouple-USB-interface/ta-p/3533..., here you will find an example that could help you.
Dasso
(3,661 Views)
