sound analysis
Hi Everyone, I have one microphone, cDAQ-9181, NI-9234 Module, NI sound and vibration toolkit.
I'm new to sound analysis.
I'm testing the sound analysis of the electric oven by putting a microphone inside the electric oven.
After I turn on the electric oven, I intend to measure the sound level within the electric oven.
If the sound level is in spec, the oven is "OK", If the sound level is out of spec, the oven is "FAIL".
By the way, I found that the electric oven is not soundproof. it's semi-soundproof.
During the test is progress, When I clapped my hands outdoors, the dB Level(amplitude) of the 1/3 octave analysis graph change a lot in all frequency range(20Hz ~ 20kHz).
When I clapped  my hands, the external loud noise level exceed the sound level within the oven.
Here, I have a question.
Is it possible to do the sound analysis of an electric oven under the external loud noise environment?
Aditionally, Is it possible to remove the noise like "clapping my hands"?
Thank you in advance...
(3,784 Views)
Hi fredik,
What's the purpose of a sound measurement when it is influenced by external noise?
Usually people use special labs for sound measurements…
Have you ever heard of "noise cancelling"?
It works like this: you put an additional mic outside of your DUT to measure external noise. Then you apply a filter on that noise signal (to handle phase shifts and filtering due to the DUT itself) and subtract it from the sound measured inside the DUT…
(3,735 Views)
GerdW, Thanks for your fast reply...
I have never heard of the "noise cancelling", but it's very interesting.
That's a good idea...
I will try it... Thanks
(3,725 Views)
